AMp and Sub problems!! DAM SPLX!!
LE2, Leicester
Ok people..HELP ME QUICK!!
Just got an SPL X 300 watt amp and two 12 inch SPL x subs. The amp is a 2 channel one i think.. (2 input..- left adn right channel??)
Plugged it all in...1 second of music..and BAM! Protection light comes up.. therefore, no music.
The wiring is all firm and secure..and please don't get telling me all about Ohms an frequencys..well, if you do..tell me what it is and how to find out what my system has!!
Please help me!!
I want to be heard before im seen!!
Chris
custard boy said:
turn down the gain on the amp.
also how about a help me quick PLEASE!
Hmm...gain on the amp...
It doesn't have a gain switch..only 2 knobs on it ..1for 'frequency..rangeing from 50hz to 150hz (tried chagin that)..and on for 'input level'..going from min to max.. On min you can't hear the subs and on max they cut out..middle..they play for 1 second and cut out...
Thanks so much for the quick reply by the way.
And, i did say please at the end of my post!!
Chris
Don't know if this will help but try turning your input level switch to min, then turn your volume control on HU to about 3/4 volume, then turn the input level switch up until the speakers start to distort then turn it back slightly that should be the maximum output you can get out of the amp.
Steve
You are driving the amp too hard. I'm gonna guess that the subs are underpowered, and the amp's sending a clipped signal at lowish volumes, which is not good :(
