Never realized till today that the black box which holds the air filter actually has two air intake openings!! One connects to the air intake pipe - I guess for breathing cold air, the other one (which I discovered today at the bottom of the box) opens directly into the engine bay - probably for hot air?
A flap between the two openings connected to some kind of spring + lever which controls which intake should be opened or closed. But I'm not sure whether this is functional in my Uno
I checked when the engine was hot (after about 10km drive) as well as when the engine was cold, in both cases the flap position was such that the actual air intake was closed and the engine bay intake was open!
Anbody aware of how this should work? Is this the right position? Cause if it stays the way it is, it means that the engine is always breathing the hot air from the engine bay and never gets fresh cold air. Won't that affect performance?
mqs
mqs
