DC2DC technology is not new, but it came into its own in the RV industry with the introduction of the “smart alternator”.
I have an Audi S4 which has a smart alternator. Seven years ago, I disconnected the sense wire from the negative battery terminal as I was sick of the start/stop mechanism. Before I did that, I observed the charge mechanism and initially the charge voltage was around 14.2V, peaking to over 15V on overrun, and once the ECU had deemed the battery sufficiently charged, it reduced the voltage to result in near zero charge current. This was done in coordination with the local AUDI workshop. This resulted in deleting the Start/Stop as well as preventing the ECU from knowing the charge status of the battery – leaving it as a normal “dumb” fixed 14.2V alternator. That battery is now 8 years old and still going strong. The AUDI techs tell me the usual life of the S4 battery is around 4 -5 years. So, a Win-Win for me there.
When it comes time to replace the battery in a “smart” system, it is normally required to connect to the ECU with an appropriate scan tool to reset the battery data, so the ECU is informed of the new battery and the associated battery data. This does not occur just by simply disconnecting the battery. Your ECU would be programmed only for the standard starter battery it came with. The algorithm built into the ECU modifies the charge regime based on that battery data, start/stop cycles, age charge/discharge current etc.
The system you have will work of course, just not as efficient if the correct charge voltages and regime was set. That is the way most house batteries were set up in the old days. But now with the relatively cheap price of a decent DC2DC the game has changed – particularly if lithium batteries are used. A strict maximum of 14.2V to 14.4V for bulk charge, and a fixed 13.5V once they have fully charged - otherwise cell damage can occur. If sticking with lead acid and employing the necessary deep cycle (not starter) batteries then the correct charge regime is 14.7V bulk, with a reduction to anywhere between 13.5V to 13.8V on float. By using a DC2DC physically located at the house battery bank, you will get a much faster charge rate as the voltage will be at 14.7V at the battery resulting in an efficient charge regime, regardless of the alternator output voltage. Most people, particularly those living off grid require an efficient charge cycle to recharge the house battery as quickly and safely as possible. Your load demands may be different/lower and so not to concerned about efficient charge methods or battery life.
