Mate gove me 5 mins at hopeton , And ill have it off.. O wait STEVEN broke m,y hammer lol
Clock34 said:mwahahaha... and yeh, more like 3 hours now ive moved house... keep forgeting just remember coming down last time i came to yours!.
jatkinson said:Andi .. Jacked my car up and undone the nuts .. and guess what .. My wheel ... it came off...
abyss113 said:WILL do it if not someone has welded your wheel on in your sleep
jatkinson said:what side are you hitting it from ?
abyss113 said:turn the wheels so they are pointing out wards then hit the hub with a stell hammer preferably a small mash hammer and rotate the wheel an inch or so everytime redo for about 2-3 rotations of the wheel to crack the rust on the hub if that doesnt work take a screwdriver flathead and place it along the gap of the hub and wheel then hammer it down between the hub and wheel forcing it away from each other this WILL do it if not someone has welded your wheel on in your sleep
Mrcento said:it'll be last time i ever drag a welder down to ayrshire, i'll tell you that much
gengis said:Andi, are you man or a welder..?
Slacken off the wheel bolts half a turn, and take the car run up the road 200mts weaving from side to side. This should loosen the seal.
jatkinson said:Dont suggest Axel stands to andi ... we all know what happens when andi and axle stands come close
Clock34 said:then use all 4 of them andi!
Mrcento said:in safe areas like chassis rails etc...not under fuel tanks
