alloy size help
alloy size help
T
Toni
looked on ebay and this came up
Rim Information
Tyre Information
Metal Type:
Aluminium
Tyre Type:
Rim Width:
Tyre Width:
Rim Diameter:
Aspect Ratio:
Offset: --
Load Index:
Number of Studs:
Speed Rating: W:
Stud Diameter: --
Tyre Manufacturer:
Rim Manufacturer: --
Rim Structure:
Manufacturer Part Number: --
say i was to purchase n, what is the main fields to be completed in with which info??
Offset: 35 to 40
Number of Studs: 4
Stud Diameter: 4x98
You can fit 4x100 with special bolts (Wobbly bolts)
you will need spiggot rings to get the centre bore to 58.1 (Very Important!!!)
If you're getting 17" wheels, the tyre size you need is 205/40/17
Do a search on the forum, has been asked many times before!
R
804
R
I
6K
I
I
876
ian Gardner
I
3
1K
Tommy K
T
C
2
555
A
