Technical Alguien ha conseguido conectar con la centralita del airbag Red 46476039?3
ppgl10
Con en multiecuscan (versión gratuita)al fin he conseguido contactar con la ECU del motor pero no así con la del airbag. Alguien me puede confirmar la lectura de esa centralita con la versión libre del multiecuscan?. Muchas gracias. Tengo un problema de cableado q me está volviendo loco.si alguien me puede orientar.....muchas gracias
Translation:
With Multiecucan (free version) I finally managed to contact the engine ECU but not with the airbag. Can someone confirm the reading of that switchboard with the free version of the Multiecuscan ?. Thank you. I have a wiring problem that is driving me crazy. If someone can guide me ..... thank you very much
With multicacus (free version) we have managed to contact the engine ECU but not with the airbag. Can someone confirm the reading of that switchboard with the free version of multiecuscan ?. Thank you. I have a wiring problem that is driving me crazy. If someone can guide me ..... thank you very much
