I bought a cheap alarm and I'm trying to fit it on a very late Cinq Sporting (one of the ones with Sei type stalks and handbrake).
I've got the alarm fitting notes posted by Custard here and was trying to connect the wires for the indicators to the alarm unit. The notes say "blue wire located at steering column and/or blue wire with black rings located at steering column". OK, I find the wires coming out of the connector block for the stalks. Access is a bit tight, so I pull the connector and, in a rare moment of extra caution, test the indicators. They work! They work with no apparent connection to the stalks. At this point I reach for my multimeter only to find that it's kaput.
So, I put everything back together, drive home and ask you folk.
Any ideas, peeps? Do you think I should follow the Sei alarm notes, wherin it states: connect to the light blue and green cables located on the back of the blinker button (hazard light) on a white 8 pin connector.?
