Alarm
Alarm
J
Jag
Friend has 1.8 HLX his key fob has broke on him. He can't disable his alarm now and it just goes off when it wants now. Not sure what he needs to do but he says he needs the key fob from a donor key?If this is right has anyone got one???How can he disable his alarm???
Jag
if you take the cover off the drivers side fuse box, there is a black plastic cap, if you remove the car there is a small key hole that looks like a broken circle, you should have a small black key with your set of keys if not you will have to improvise, on either side of the hole is on and off, if you turn this to off it will disable the alarm
Lozz
Lozz
Sorry for late reply again!!
Im from wolves, but often around leicester and coventry area? And you???
Jag
i'm just outside walsall let us know if u want to com pick up the key
Lozz
Lozz
the key is for my mate, he has the 1.8 HLX. How much do you want for it?? So where about are these scrappies in walsall. Dont know exactly what he needs??
Jag
you can have the key if u want it
The scrappys are in willenhall and darlaston
The main on is called Auto Bits
Lozz
cheers for the help Lozz, will speak to my mate see if he can pick it up or i might have to. Will post when I know.
Jag
Lozz can I pick up that key sometime on the weekend??
Jag
yeah no probs, i'm at trax on sunday so it will have to be saturday is that ok with you?
Lozz
Yeah that sounds fine. Just give me a time and place best for you.
Jag
Dont know Walsall that well but think i will be able to find it easy enough. What time???
can do it tonight if you want? where bouts are u in willehall?
Lozz
Lozz,
Dont want to put you out and iam not in willenhall till saturday. So at the McD's sounds good. Just give me a time.
Jag
C
354
Craig
C
A
2
266
Ozric-Al
O
S
17
2K
StiltonBravo
S
A
236
Anonymous
A
