i have been browsing the the workshop manual in attempt to detect alarm failure. interesting to note the cd gives procedure on how to reprogram the country code of the alarm and it also mentioning the simplified procedure on how to "pass over " data to new alarm ecu without the use of examinar or other diagnostic sotware.
however i am not able to find out what are the steps to reprogram the new alarm control unit as i can't find it any where in the CD.
checking thru brava/bravo/marea service manual do indicate the procedure called as Simplified Programming or Programming with closed memory.
i just wondering whether is it the same procedure ? ( Control Unit Programming procedure = Simplified Programming or Programming with closed memory) because the rest of the procedures mentioned in the service manual are similar to both of them.
any one familiar with this?
the alarm pin-out is similar to both of them
