Hello, first of all I introduce myself, my name is Aaron I have a Fiat bravo (198) from 2007 1.9 multijet 120hp.
Recently the light came to me with the fault message in aribag, I checked all the connectors, I passed them the tester and the voltage marks it perfectly, in the end I bought a specific diagnosis machine Autel MaxiLink ML629.
I got 2 errors in the airbag control unit 1 of voltage higher than the battery limit code: b1002 and the other control unit damaged, interior errors code: b1001. Looking for information to repair the high voltage issue, I changed the alternator pulley since the old one sounded when starting, I discharged the battery and the high battery error disappeared (Now I get that the voltage is low but reading more thoroughly is for the switchboard) my problem is that the error in the switchboard keeps coming out and I think I have to change it, the problem is that I can't find it through the scrap yards, let's see if hopefully I can get one, my question is if someone else has happened and how you have solved it since it is a problem that takes me headlong and I'm fed up.
Thanks in advance.
Thanks in advance.
