Technical Airbag light
I've had my airbag warning light on since changing out my PAS. My cheap diag tool says there are no errors so I'm stuck, wondering if it is the replacement electronics on the column or the airbag needs replacing. You can be sure it's going to be expensive lol
if you used due protocol when shaft changed then light would extinguish on self test
you've obviously broken something
fiatecuscan with appropiate cable hasnt failed me yet and i see all peoples bodges whether they be postmen or ladies of the night
I followed the guide on this site and allowed for the time the op didn't and light still came on. I looked today and all connections seem correct and in correct places. Any one know if the steering ecu is the airbag control? As that is under warranty for another year or would it be easier to go get a diag at a mechanics?
Thats because cheap diag tools are typically only for general engine fault codes and not Airbag ECUs etc.
