Ducato Airbag light is on
Mikeyman63
Ödeshög
Hello friend.
New on this forum :)
The airbag lamp is turned on in my Ducato 2.3 multijet, yearmodell 2012.
I have cleaned the connecting under the seats and the two connectings at the ECU on the floor.
Erased the codes.
Airbag lamp still lighting.
I have done a scanning with my tool and it says:
B0102
Connec. to ECU container ground.
DTC status: precent.
Have someone any tips for me, please.
Contact Northern Autotech Services. I took my motorhome to Morecambe where they tested the air bag module, repaired it and refitted it in a hour or so. They also do a postage service. Do not depend upon Fiat, I have been waiting to hear from my main agent who ordered a new module last November. http://www.northernautotech.co.uk/
This is their ebay listing. They say:
We can also help if your ECU has the hardware grounding error B0102-00 Connection To ECU Grounding. Please contact us
first if you have this error.
Hi Mikeyman
This error code indicates a fault in the connection between the metal case of the Air Bag Controller and the Vehicle Ground. I suggest you remove the 3 (?) nuts, clean the contact areas and reassemble. Maybe the position under the floor makes it vulnerable to water from snowy Swedish Boots :) ?
There is another ground connection via a wire from the Air Bag Controller M060 to the Ground Point C050 nearby. I suggest you check this out too (See pictures).
Det här är deras ebay-lista. De säger:
Vi kan också hjälpa till om din ECU har hårdvarujordningsfelet B0102-00 Anslutning till ECU Jordning. Vänligen kontakta oss
först om du har det här felet.
[URL FALLER ut = "true"] https://www.ebay.co.uk/itm/26521451...DTCOvXKjiuf65LfIJlD%2BQYZtMxsvEGBceJGicU3BD2R % 252F3% 252F8EMmIET1Cm0MNSnTd2VTlRzOM2glXR5H2AZqNsUAFS2THe0YWw2vp1EgWv61EHo35YD% 252BNGyr0wAPgmCvdppsq6nDgSW8QsqaJMOHJ1pLsTS% 252BdLH46geMMFzoNZT3U210xTT1JYjpB3a8TYE% 252BErJab0NqVAvm7BbQX5He3ih9NQov77Rf7khp61eOMvUoI6qbpk54slWMy9Lmeugz6pWgPtCAdTD30X6xHdAJSMDt247:LOL:q% 252BXdqxpXAQmBa% 252BwQZDVn3Tvmk2fPv2WrFqOrxLUpwpgoDP4QI3EWNalQYjIn4MChXRTPHmDci23Oh9cFc0FRibunEQWHDjK4J% 252FjkWT3wEAqZo5x5lSKJ1TlBMxrIQO6GQ% 252BQfKcNC97RVsvZYYx8QW9EUljHTLcVKzQYcVRi% 252B50nNF74OvRuucJGEjolXQVfV% 252Fk7Z9ybonPWAiZSR99% 252FjkYTtawSsfRjri% 252Bvj5XaITjAG% 252BJosujcfWidQm% 252FJPT9uAoV4GXoh03XSTlCdHGCRDEuSQiNtP2lERP27c8vdE6O9l% 252FhkdUihtyeL34bTIts8HynidTzA% 253D% 253D% 7Cclp% 3A2334524% 7Ctkp% 3ABFBM2uuYwd5f [/ URL]
Thank,s a lot! 😊👍
[URL faller ut = "true"] https://www.ebay.co.uk/itm/26521451...DTCOvXKjiuf65LfIJlD%2BQYZtMxsvEGBceJGicU3BD2R % 252F3% 252F8EMmIET1Cm0MNSnTd2VTlRzOM2glXR5H2AZqNsUAFS2THe0YWw2vp1EgWv61EHo35YD% 252BNGyr0wAPgmCvdppsq6nDgSW8QsqaJMOHJ1pLsTS% 252BdLH46geMMFzoNZT3U210xTT1JYjpB3a8TYE% 252BErJab0NqVAvm7BbQX5He3ih9NQov77Rf7khp61eOMvUoI6qbpk54slWMy9Lmeugz6pWgPtCAdTD30X6xHdAJSMDt247:LOL:q% 252BXdqxpXAQmBa% 252BwQZDVn3Tvmk2fPv2WrFqOrxLUpwpgoDP4QI3EWNalQYjIn4MChXRTPHmDci23Oh9cFc0FRibunEQWHDjK4J% 252FjkWT3wEAqZo5x5lSKJ1TlBMxrIQO6GQ% 252BQfKcNC97RVsvZYYx8QW9EUljHTLcVKzQYcVRi% 252B50nNF74OvRuucJGEjolXQVfV% 252Fk7Z9ybonPWAiZSR99% 252FjkYTtawSsfRjri% 252Bvj5XaITjAG% 252BJosujcfWidQm% 252FJPT9uAoV4GXoh03XSTlCdHGCRDEuSQiNtP2lERP27c8vdE6O9l% 252FhkdUihtyeL34bTIts8HynidTzA% 253D% 253D% 7Cclp% 3A2334524% 7Ctkp% 3ABFBM2uuYwd5f [/ URL]
Thank,s a lot.
I will check if there is many documents/customs duty for shipping parts for reparation to a country outside EU
Hi Mikeyman
Hi Anthony.
This is perfect. I forget to write that I have mounted an external cable from the nut/ECU metal case directly to ground on the battery. It didn´t help.
But I will check the M060 also now!
No driving with my mobile home in the winter her in Sweden so it,s clean and dry ;-)
Hi Mikeyman
Hi Mikeyman
Hi Anthony.
I tried with a external cable from the metal case of the airbag controller to battery ground and another external cable from the C050 (nut attached to chassi) and to ground of the battery. Clear the faulty code and started.
The airbag lamp is still on :(. Maybe it is time to go to the Fiat dealer for investigate ... 👨‍🔧🤑
Have a nice day!
BR Mikeman
I've fixed B0102-00 myself, it has usually not much to do about the ground issue, fault is permanent.
It requires hot air station, CH341 programmer (can be cheaply bought from Aliexpress).
Eeprom needs to be desoldered and memory reprogrammed - memory area between CE0 and DE0 needs to be cleared (FFs) and Eeprom needs to be soldered back.
I am happy to help out.
There is also a guy in Poland which can do it for around 100-125EUR to save you some hassle.
Hi Tomson, i am from Czech Republic and i have this problem too. Is any contact to you. I need little consultation please. Thank You,
I am just a hobbyist and speak broken Czech, feel free to post a message here. I will try to help you out so everyone can benefit from a public post.
OK, do you have some photos of inside airbag ECU? I dont know where is eeprom and if is hard to remove it.
