JohnMuppet
- Joined
- Sep 5, 2021
- Messages
- 4
- Points
- 2
Hi everyone!
I am sort of in a desperate situation. Earlier this year my van (2007 ducato/relay/boxer 2.2hdi) failed the MOT due to the airbag lights being illuminated. My local garage was unable to connect to the ECU and diagnose the problem, so I decided to do some diagnosing myself.
Eventually I was able to locate the airbag ECU and noticed severe corrosion on the unit. Tested the unit, and it was completely dead.
Got my hand on a second hand unit (with matching numbers 1356791080), plugged it in and the one light is now flashing and the "airbag failure" message appears on the screen.
My local bodyshop told me that I needed to get the new unit cloned, so that it appears as the original ECU. I then got the unit cloned and refitted, but nothing changed.
I took the van to the dealer (it's labeled as a Citroen), who then performed a diagnosis (which they refused to give me a copy of btw
!) but couldn't find anything useful...
I decided to get my own diagnosis software and hooked it up to the van, and everything points to the ECU. I then called the dealer and asked them about a new replacement part, but according to them the ECU model fitted in my vehicle is discontinued and they can't replace it. :bang: The knobhead then told me that the van is basically unrepairable
In sheer disbelief I decided to try my luck with Fiat. They confirmed that the part has been discontinued, but was unsure about whether they could replace it with a successor model. They have now sent an inquiry to Italy and I am awaiting their response.
Have anyone of you had this experience with the airbag ECU and/or a discontinued part?
Is it possible to replace the ECU with a second hand one, and does it need coding, cloning, proxy alignment etc.?
I am in desperate need of help. I don't want to give up on my van just yet!
Thanks in advance!
Thanks in advance!
