Hi
I have a 1996 Barchetta. The airbag ECU died and I am having a hard time getting parts (apparently Henk has passed away? And the parts sent do not work for my mechanic). From my mechanic:
One of the modules gives me the fault code 201 "airbag module fault" and the second module which I have just tested is not communicating at all with the diagnostics computer. I have reverted back to the first module to ensure that I do not simply have a blown fuse or other issue that would explain not being able to communicate with the second module received but this is not the case, ie I can go back and communicate normally with the 1st module.
For your information I am able to provoke new faults (disconnect a pretensioner or airbag charge) and then clear those faults but the fault 201 is permanent and will not clear.
Many thanks for any assistance you can provide.
Also - I will search the forum but is there another place to buy these? I probably can get them on ebay.
See attached with Serial Numbers etc.
- Model
- Barchetta 1.9
- Year
- 1996
- Mileage
- 105000
