Technical  Airbag ECU Location
Minimarcus69
Hello all, first post so apologies if I do anything wrong! Am trying to find where my Airbag ECU is located on my 2012 Fiat Bravo 1.4 16v turbo. Seems I have fried it Juno starting my car. Just need to find it so I can buy the same number replacement
Thanks in advance
Normally these are located centrally, inside the car cabin, under the heater unit on the central tunnel in front of the gear leaver.
Follow the yellow cable(s) under the dashboard.
If not found there then look under / around the front seats and centre console.
You can use ePER on this site to get the correct part number by using your full chassis number.
