Technical air filter pipework
TURBO1397
Rhodes - greece
hi folks. im trying to source the plastic air filter pipework that goes from the filter housing to the engine. im in greece so parts are very hard to come by and very expensive if i have to buy new, also the car will be a euro spec as well i presume. As you can see it has been buchered and the car isnt running well at all.. hopefully attaching a picture so peeps can see what pipe im after.. cant find anything on the web regarding a doblo with this pipework??
Possibly available from a scrappy here, and it may be used on other models.
But first, we need to understand exactly which engine and Doblo you have. There have been several Doblo models, and we should never assume that anything caries over without change.
Year
Series if identified. Important if near a change date. The three-digit model series would be ideal.
Engine. Presumably from your moniker, it is a 1.4 petrol. But is it turbo or not?
thanks for reply..it is a 2004 1.6 16v doblo.. i cannot for the life of me find anything on the internet regarding it (pictures or otherwise). I 'think' the stilo has the same engine but i think the pipe is different..
Seems it only fits Doblo.
And there are two alternatives.
51701696
51805366 North - Europe
Not sure what the note about north-europe means. Is this us, or only further north and colder? Your full VIN might show an exact application, don't publish it here, send me a PM.
This shows the pic, but two part numbers.
https://www.fiatdalys.lt/en/catalog/parts/102/23/1/1/3C/0/0/M26/0/GS/air-filter-and-piping
This shows the north-europe part.
http://razborka.ua/251977
Extra little box could be one of two things. If it has pipes going to it, dependent on where they go, could be a breather flame trap, condensation trap, or oil condenser. Or it could just be a resonance chamber. Stops the intake air resonating, smooths it out.
Good job you confirmed the VIN. Seems it is earlier than it might appear, and cheaper as a result. The car was manufactured May 2004, so fits iinto the 2004-2005 category for parts lookup. The air intake pipe fits all 1.6 from 2000 to 2005. With the VIN input into ePER, it greys out parts not fitted to your vehicle, (if it knows).
The part number you are looking for is 46829488 Listed a couple of years ago at around £20, so hopefully not too much more now. The sites you've been pointed at so far may help, or just Google it.
PM sent with more vehicle details.
Many thanks for all your help.. I was at a dead end trying to find this. Looks like I can get one for €25.. hats off to you sir! :)
