Air-con
Air-con
fifilebleu
When using the air-con in my 2004 Doblo, water drips onto my passenger`s feet. ? split pipe or worse ?
Anyone else come across this?
Blocked drain
All aircon systems generate water in the car when running, there is usually a pipe which carries the water out into the engine bay where it can drip down onto the ground, if the pipe gets blocked it drips on your feet.
On the punto the pipe is in the area of the cabin air filter, take the filter out and look for the out flow, I would imagine the doblo is very similar in design
