Technical  Air Con Fan Angler
JAY81UK
Hi, the two fans above the radio where you can direct the airflow... one of them you can no longer angle, presumably because the angler has come off the rail of the blades.
Is there a way to fix it? I have tried but with no luck. Thanks.
Happened a few times to me, and I manage to click in back together using the screw driver in the boot.
They need lining up a little or it’ll keep happening when the temperature changes and causes the plastics to stick together and cause it to unhook when trying to move it [emoji1360]
