Technical Aerial base
Remove boot trim and pull the 2 plastic retaining plugs from the roof then take out both the side panel trims the fixings screw for those are behind the airbag emblem
Don't worry the air bag is not behind this partyou should then enable to pull roof lining down enough for access to the 13mm bolt
Brill thanks for that! Once new base arrives from Italy will give it a go!
Can't these bases be repaired at all, my 2017 1.6d has the same fault and the idea of spending £90 ( the cheapest I've found) just to listen to radio 2 hurts
