vincentvega
- Joined
- Aug 12, 2014
- Messages
- 5
- Points
- 1
Hi all,
Im hoping I can get some advice regarding a current situation I am in.
I have a Fiat Doblo Multijet van, that went in to a local garage for a new clutch. Whilst in said garage I received a phone call informing me that my water pump had a leak. I agreed to the price to change the pump, no problem.
So I picked the van up, all fine. 3 days later the van suddenly cuts out on motorway slip road, not turning over, nothing at all.
AA recovered me, and diagnostic machine picked up a timing issue.
Got recovered to a garage near to where I broke down, garage looked at engine and agreed its a timing issue, None of the top end was moving, but bottom end was.
I spoke to the garage who changed the water pump and told them I am bringing the van back to them as I suspect the problem may have something to do with the changing of the water pump.
Am I correct in saying that when changing the water pump, the tensioner on the timing chain would have been loosened thus altering the timing?
Or is the water pump on a Doblo driven by a separate belt?
Would anyone have any advice on what's happened?
Doe's it sound like the timing hasn't been set correctly or the tensioner not tightened?
Also if the garage are looking liable but not accepting fault, how do I go about approaching the situation?
It seems a huge coincidence for it not to be anything to do with the water pump change if its driven by the timing chain.
Many thanks in advance
Josh
Josh
