Hello.
Found the following problem.
When you press the gas pedal to the end, the throttle opens to 65-68 degrees, you can open it even further by hand, up to 85 degrees.
I tried to adjust the cable on the attached throttles, if I tighten the cable sheath, the valve starts to open.
How to adjust the pedal?
Punto mk2b 1.2 8v
Punto mk2b 1.2 8v
