Technical  access required for cable run into cabin
hi derby doblo i have alpine sub under front passenger seat. Look under carpets in footwell at the front where engine bay is divided from footwell.And there should be rubber grommet put small slit in it and shove cable through.Hope this helps regards carlos:) :) :) :) :)
I had to drill a small hole in mine and insert a grommit just above where the carpet ends right up in the top of the footwell. Just triple check there's nothing either side.
Running the cable to the rear (assuming you are) is easy, just unscrew the kick plates by both doors and it all comes off, do the same on the other side for the RCA and job done :)
just complete thanks for the advice used the passenger footwell grommet and worked a treat!, sub is in a bespoke box under the drivers seat as boot is taken up with tools an equipment very pleased sounds gr8 :)
