Technical  Abs sensor 2007 x250 3.0
11WINGNUT
How can i remove the froth abs sensor on an Ducato ? Also any easy way to replace bearings without removing hub? (ok i should know by now) I have been hours at it and getting nowhere fast i just fitted a new gearbox. But failed test on 3 bearings and spring bushes from lack of use Is a press required for both springs and hub?
The detailed procedures are described in the eLearn manual for the X-250.
Especially the bearing replacement is not possible without an hydraulic press that can deliver more than 5 tons pressure, so that is no DIY job.
You do realize that they are a one piece bearing not a hard job but the hub has to be removed even on older bearing designs with cups and cones the hub still has to be removed to knock out the inner bearings , you can buy a hub and bearing unit complete though if you find that easier Cheers Adam
