Technical  ABS premature function
keef6666
Cannock
:) Hi,
The abs system on my Multipla 1.9 JTD is coming prematurely, after a few miles the ABS light comes on and the brakes are okay. I have checked the two sensors at the front and they seem to be working fine but I cannot find the connectors for the rear sensors, any ideas.
Secondly I would like to know where the ECU plug is and if you can get a fault code reader for this MPV. Thanx.
(y)
with a multimeter but the front N/S side sensor is brand new anyway and I have found the connectors for the rear sensors and used the multimeter in the same way:) I think I need a oscilloscope to check the actual Hall effect sensors though?
(n) Took it to Fiat garage today put on diagnostic and double wammy, the front N/S sensor is not recording the correct number of teeth and either the same side or O/S front wheel bearing has gone.
Thought the diagnostic was cheap though and well worth £25 at Bostins @ Milford in Staffordshire, friendly bunch and efficient.
Taking the car back tomorrow get new bearing and maybe a phonic gear!(y)
Remember BOSTINS OF MILFORD (STAFFS) are:worship:
£25 is cheap(y)
I would still quickly check the connector though as this throws up o.c. errors.Behind battery is abs module,on left side of it is a long black connector.To disconnect pull the 'handle' towards you(will be tight) like your opening a drawer,refit in opposite way.
(y) New bearing and no ABS brake problems this was well worth the money. Car is now cool in this heat!
