Technical  ABS EBD lights on
ABS and EBD warning lights and stop engine message coming on -
I have checked continuity of sensors and its around 39ohms for all four at loom plugs and at abs unit plug, checked for all 12 volt feeds and earth, all is ok, cleaned corrosion from a couple of 12v live pins.
Lights and message still on, is the only way to clear faults with garage code reader? I don't have a laptop or a multiscan so can't do it myself.
Suppose worst car scenario is water has got into abs unit electronics?
Lamp's should go off iff all is ok.Can you help me,do you have wiring diagram of abs connector?
Hi, a bit late for me to answer now but I bought a workshop manual on a CD, I also downloaded one for a small fee from an internet site.
I had a second hand abs unit fitted and the fault was cured, presumably water had got into the electronics somewhere.
