General ABS Faulty Message Keeps Appearing
DASHBOY
Hi
I have a Fiat Ulysse 2.0jtd 54 plate.
The problem is whilst driving the ABS faulty keeps coming up on the screen and at the same time the red stop light comes on just above the steering wheel.
Should I take it into the garage and get the brakes checked?
Can anyone advise on this its really annoying?
Thanks Dash
You need to connect a diagnostic tool to your car's diagnostic socket in order to find out which element of the ABS system is faulty. The Peugeot Planet2000 system works well with the Fiat Ulysse. The most likely cause of your problem is a faulty ABS sensor on one of the wheel hubs, but the only way to be sure is to interrogate your car's diagnostics.
I agree with Avionista - though it could be any element of the ABS system. Cleaning the rotors and sensors is often a cure, based on my previous Citroen experience - don't forget, this is a Peugeot/Citroen van...
