Technical  ABS/ASR failure message on start
Kisa082
Hi all!
I changed yesterday the front brakes, and now when i start the car, get the asr/abs failure messages, the messages dissappear after start the engine, no failure lights is on. I pull off the connectors when i changed the brakes, the computer stores the errors because of this?
Thanks for the help.
Happens if battery voltage low, or if battery terminals not fitted properly, it has nothing to do with your changing off brakes, its to do when you pulled of battery connectors,
Check battery and connections.
