Hi Guys,
I'm new at the forum and wanted to share with you a few troubles I have in my fiat, so maybe some of you can come up with some ideas to solve the issues.
1 - When I switch turning lights on, they work properly but if I press the brake pedal, they turning lights come off, i.e. they switch of the turning lights is still on, but the lights are off until I release the brake pedal. Thus, I cannot have turning lights and brake simultaneously.
2 - The temperature gauge usually shows the temperature not higher than the first quarter of the scale. Since most cars usually work at the middle of the gauge scale which is about 90ºC, I'm wondering if my fiat is working too cold or it is only a gauge issue, or it is a normal thing and can be accepted. What can be the meaning and effects of this?
3 - When I start the car, during the first minutes of operation (hard to say how many because it changes from time to time) the idle is at about 1500 RPM, which is higher than the regular idle condition in most cars. And it is so high, that if I turn in the first gear, and even without pressing the gas pedal, the car is capable of going up slight (or not so slight) slopes.
Any input you might have will be greatly appreciated.
Kind Regards to you all,
Leo
Leo
