Having Idle problems after replacing the head gasket on my mk1 Punto 75sx 1.2L 8v, (so Multi Point Injection). The car was off the road almost a year before I finally finished the job.
Build/Progress thread is here:
https://www.fiatforum.com/punto/338090-my-200-95-mk1-75sx-paddy-punto.html
Anyway, to the problem......
- Overheated over a year ago (October 2014) with suspected head gasket problem. Turned out to be stuck thermostat, which I replaced. The overheating had caused water to start leaking out of water pump, so this was replaced.
- Decided to replace head gasket, so had cylinder head skimmed, I re-lapped the valves and cleaned ports etc.
- Head gasket back on, had trouble with timing at first but then got it right, then timing belt teeth started to rip off (not tensioned tight enough/generally perished).
- New timing belt & tensioner, car started fine, but was now idling badly...
- When car is started – surges slowly up to 3000rpm and beyond until you touch the throttle, then it drops to 1500rpm, fluctuating up and down to about 2500 constantly (bruuum-bruuum-bruuum etc.)
- Had this problem a few years ago – replaced Lambda/Oxygen sensor which fixed the problem that time, but unplugging it now does not affect idle at all. Also replaced coil pack and fuel filter before this point.
- Trying to fix this problem recently: new Throttle Position Sensor, new Idle Control Valve, cleaned throttle body, ECU reset procedure, unplugged Lambda sensor, checked coil pack sparks, adjusted throttle cable.
- No luck with any of this, now thinking it could be the MAP sensor (can’t think of anything else). When the wiring to MAP sensor is unplugged, car won’t start for more than a few seconds.
Getting frustrating now as I've thrown parts at this problem and had no luck, that's even before I tax and MOT it....:bang:
Any help would be much appreciated.
