6x9's and sub wired to standard head unit
Yes.
you need a line out convertor to be able to connect the amp
personally i would avoid 6x9's because of the shape of the cones they seem to distort too easily, something to replace the rear shelf speakers
sat nav head unit tends to have problems with duff screens
No you'll need to run a positive from the battery and ground to somewhere in the boot.
Switched live from the head unit.
You need to basically get an amp wiring kit which is appropriate for the size/power of amplifier you choose
There is no RCA out on the Head Unit, that is why you would need a Line level converter or an Amp that has line level inputs.
All that is a lot of effort though for a Punto. I would just put an aftermarket one in.
