the old style injected pandas all had a different fuel tank. the closest tank would be the panda 4x4 injected fuel tank. which was the same shape as the marbella's tank, just had bigger openings to put a fuel pump in.
anyway i am not going down the line of swapping fuel tanks over. not when i can get an in line fuel pump from somewhere.
i now have all the engine parts. going to stick a youtube video up of it.
found out that the single plug with orange wire from out of the loom connects to a green with black stripe wire, that leads down to the fuel pump. so that is one plug down.
the plug with 2 wires go to the injector/ECU light on the dash.
the single red connector i am still guessing is battery live.
however. my guess is something is not right. the ECU has to have a ignition live somewhere! otherwise how does it know to turn the engine off, when you turn the key to off. ???
so i still think that on the plug with 2 wires, one goes to the injector light, the other goes to an ignition live.
does anybody have the pinouts for a 6F ECU?
