Hi, To OP.. can I ask how fast the changes are (and how smooth) on the auto gearbox? Is there a big delay between gears?I am really interested in the turismo, but after livivng with the perfect shifting, seemless, DSG VAG box, I don't know if I could live with an inferior box.....
Clearly Fiat would have preferred to fit it's TCT dual clutch transmission like the one on the MiTo, but apparently there isn't enough space for it and the dualogic transmission isn't robust enough for the Abarth's torquey engine.
Therefore Fiat took the same 5 speed Abarth manual transmission and bolted on an electrohydraulic shift and clutch actuation mechanism to it.
Since it is not a sequential gearbox and only has one clutch, it cannot offer the shifting speed of a DSG/TCT/DCT...
For something that sounds like a hack, it works surprisingly well. I test drove the MTA Competizione again last week and got a bit more used to the MTA. I ended up not hating it as much as before though I still didn't like it.
I prefer manual transmissions, but I'm not a bigot. As I said before, I drove a dual clutch sequential equipped MPV 2 weeks ago (a new car for my wife) and I would have selected the dual clutch had she not insisted on the manual. It was really nice. The upshifts and downshifts were fast and smooth while happening at just the right time. It was really good!
On the Abarth the shift speed felt like about the same speed as a hydraulic automatic transmission, but not as smooth. So, not terribly slow but definitely not instant. For reference, it felt about the same speed as a person would do it when driving in a fairly relaxed manner. The whole time I was driving the MTA I kept thinking "you're doing it wrong! Here, let me do it" as the shift speed and especially the timing didn't meet my expectations. This can partially be mediated by moving into Manual mode and using the flappy paddles behind the steering wheel. When I remembered the manual mode and used it, I was much happier with the results.
What I really hated about the MTA was "pull away" power. With a hydraulic automatic that torque converter really gets you going off a stoplight so you can move over a lane or whatever ahead of the vehicle you were stopped next to. One can accomplish the same thing in a manual. I don't mean a dramatic burn out, but just a little ZIP ahead to get around a vehicle when you find yourself in the wrong lane, stuck behind a slow lorry etc...
I couldn't find a way to get the MTA to let me do those ZIP manuevers or even pull away from stop lights with any kind of urgency. I tried progressively more pedal pressure and I still got the same thing creep...creep....more creep...a little more creep...still creeping....maybe 3kph now...and for a bit and then seemingly normal acceleration.
Maybe MTA owners can speak up and tell me I was doing it wrong. Regardless, for me the MTA is a bit of a hack. Taking a normal manual transmission and bolting on a robot to run it can never work as well or as reliably as a transmission designed from the beginning to be an automatic.
If you or your partner cannot drive a manual, don't want to learn and really want an Abarth then it's your only choice but definitely not a great one.
