Technical 500e Reset/Reboot Procedure
Kaohsiung
This is coming up a few times now and always linked to another site for the answer, so I felt it's best I post it here too.
Method One
Can fix false alarm warnings, and failure to shut down or start &/or charge, but it may only be available when the car detects a problem.
  1. Disable "Keyless Entry" in the touchscreen (behind the steering wheel) under "Doors & Locks".
  2. Get settings mode ("gear" icon) on the speedometer screen, with the left/right arrows on the wheel.
  3. Press the brake AND start button for 30 seconds. A new menu appears: "shut off".
  4. Follow onscreen instructions. It asks twice to keep the OK button & brake pedal pressed until the displayed countdown bar finishes.
  5. After shut-down, wait 5+ minutes. Then it should work normally & you can reset Keyless Entry.
  6. If it still doesn't work, try starting the car to "ready" mode, wait 5+ seconds, then turn it off, get out & lock it, wait 5+ minutes, then restart 5 sec, off 5 min, etc. 10 cycles will sometimes clear false alarms.
  7. If it still doesn't work, go back to step 2 but leave it shut down as long as possible (30+ hours nearly always works in a 2019, but once when that failed 61 hrs. worked).
It turns off everything including the 12 V & HV batteries. Don't interrupt the shutdown with the left arrow or it will activate every error message.
Method Two
If that doesn't work, & you're stranded with a non-working car, you might try the @IanML 12V reboot.
  1. Leave the bonnet open, along with a door or the left window (for headlight switch access), & wait 5 min for sleep mode.
  2. Disconnect the 12V & wait 5 min for the system to depower.
  3. Reconnect the 12V, wait 30 seconds & without opening or closing any door, hatch, or hood, turn on the headlights. Now you’re good to go.
An AA man had to do Method 2 to mine a few months ago, so I could have done with knowing this before - did the job, anyway
