So I've reached phase two of "whats making that knocking noise?" after episode one.. 'replace suspension bushes'. And I've finally found out whats doing it!!
Its the driveshaft for the 4x4 as i suspected... I figured this as the noise goes away if i turn on 4x4 mode so tonight i unbolted the far end of the drive shaft and cable tied it up against the fuel tank so it wouldn't scrape on the road and took it for a drive and sure enough the noise was gone..
What causes the noise is the fact that theres a little play in the drive and when 4x4 is not on that play converts to a rattle/knocking noise over rough roads and bumps.
But I'm hopelessly stuck now
does anyone have any suggestions on how i can fix this?.. From what i can see.. this problem should occur in any 4x4 panda yet i'm sure other owners would have mentioned if if their car made the noise as its quite annoying...
Small play in drive shaft diff which is normal of course..
Drive shaft disconnected and soon to be tied up next to the fuel tank for test run...
