bulldog5046 faster! FASTER!!! Parked in the garage Written a guide Joined May 8, 2005 Messages 9,053 Points 1,538 Mar 30, 2007 #1 doesnt that seem a little poor? no way will you loose 22gb due to the unit allocation size.
custard Status: DEFCON Grumpy Written 10+ guides Uploaded 5 resources/downloads Joined Nov 4, 2003 Messages 48,591 Points 11,024 Location Edinburgh Mar 30, 2007 #2 windows uses a different value for 1gb over HD suppliers though
The Negotiator :) Joined Apr 21, 2003 Messages 22,169 Points 3,120 Location Nottm Mar 30, 2007 #3 No, you lose the other half because windows and HDD manufacturers have a different understanding of numbers.
OP OP bulldog5046 faster! FASTER!!! Parked in the garage Written a guide Joined May 8, 2005 Messages 9,053 Points 1,538 Mar 30, 2007 #4 that makes sence. Cheers,
EZ Tutty Patron member Joined Feb 17, 2006 Messages 165 Points 61 Location Derby Mar 30, 2007 #5 yeh it's to do with the number of bytes in a kilobyte, and kilobytes in a megabyte etc etc the actual figure is 1024 but HDD manufacturers use 1000, sounds like a small error but it all builds up, and the bigger the drive the more you loose.
OP OP bulldog5046 faster! FASTER!!! Parked in the garage Written a guide Joined May 8, 2005 Messages 9,053 Points 1,538 Mar 30, 2007 #6 EZ Tutty said: yeh it's to do with the number of bytes in a kilobyte, and kilobytes in a megabyte etc etc the actual figure is 1024 but HDD manufacturers use 1000, sounds like a small error but it all builds up, and the bigger the drive the more you loose. Click to expand... yeah i figured thats what was done, in which case its actually the manufaturer using the wrong units
The Negotiator :) Joined Apr 21, 2003 Messages 22,169 Points 3,120 Location Nottm Mar 30, 2007 #7 It's not as simple as that, GB in the terms that the HDD industry uses is SI, MS, giga meaning 10^9 bytes. 2^30 is fairly arbitrary and just close to an actual gigabyte. A good page on it: http://en.wikipedia.org/wiki/Gigabyte
