These bulbs to illuminate the fan heater displays have never worked. I am unsure whether it is each bulb or if perhaps the four of them are on one fuse that might have blown? Is there anyway to check? Where are the fuses?
check the fuse, theres a diagram on back of the fuse box cover
take the heater control cover off and take out 1 of the bulbs. Youll see if it is blown, as it will be blackend where it has burnt out. there cheap enough to replace
Thanks mate. The bulbs look in-tact. I have just had a look at the fuses, but I can't figure out which one I need to check from the diagram. Anyone know if these bulbs are on the same fuse as anything else and how I can work out which one it is?
Thanks!
Thanks!
