Another installment in my continuous investigation into the vagaries of ignition-timing specs. for the little Fiat engines.
I was looking through the Haynes manual at the detailed specification pages for the post 1985 126 engine. The Haynes manuals have been found to be wrong at times but the specs. are listed quite convncingly. The first change from the perceived wisdom is that the initial timing of 10 degrees is not made on a static engine but measured at 700rpm (idle speed).
There is an intermediate advance of 14 degrees at 3,000rpm.
The maximum advance of 21 degrees is measured at 3,850rpm.
Assuming that the last two figures are additive to the initial timing, that would take the maximum advance to 31 rather than 28 degrees as I have always adhered to previously. This might be relevant on an engine with the factory distributor if you are checking it with a strobe.
But with the 123 I have fitted there isn't any setting amongst the 12 curves vaunted, which exactly fits this shape. In fact, the degrees advanced for each setting are specified at 2,000 and then 3,000rpm and go no further.
My engine runs so well I'm loathe to tinker. But I'm
committed addicted to tinkering, so as an experiment, "
tuning-curves groups 3 and 4" here I come.
