Technical 2022 ducato LCD instrument cluster ic retrofit to 2015 ducato
nikosgrk
greece
Is it possible, has anyone tried it yet?
Do they have the same wiring connector?
They are two types basic cmall lcd and full lcd
Has anyone tried yet?
Any part numbers of the instrument clusters and and also some photos of the rear side including the connector?
Please help!!!
I tried the full digital one but it does not work. any clues?
It may be rather old, but if you download the x250 Training Manual, via the Downloads button at the top of the page, and select or scroll to page 143, there is a pinout for the 18 way connector. There is more info on previous pages. Not a complete answer, but perhaps a starting point.
I should have added to post #6, that if the instrument panel, which is a node in the canbus is replaced, then a proxy alignment would be required.
Hi, I did not find in the downloads section the x250 Training Manual, can you help locating it please?
1. Click on "Downloads" at top of page. - Menu opens at left of screen.
2. Select "Fiat Commercilas", then "Ducato".
3. Locate "Fiat Ducato Training Manual" on page 2. click on that, then on "Download" at top right side of page.
4 Two file options, choose larger one (10.3 MB), as shorter file is for 3 litre engine.
Ok I checked out the instrument panel cluster pinout as stated in the attached photo for the ducato 200-2021 model.
I would appreciate if anyone can help finding some documentation for the ducato 2022+ instrument panel cluster pinout to compare.
Please help!!!
I found this info for the new series 8 2022 ducato
C015 DRIVER'S SIDE DASHBOARD MASS (DASHBOARD)
D001A FRONT/DASHBOARD JOINT (FRONT)
H008 ELECTRIC BRAKE CONTROL (DASHBOARD)
M001G BODY COMPUTER (DASHBOARD)
M114B CAN NETWORK SAFE CONTROL UNIT (DASHBOARD)
H090B SWITCH CONTROL GROUP (DASHBOARD)
M172A MULTIFUNCTION SCREEN NODE (DASHBOARD)
M094B RADIO RECEIVER NODE (DASHBOARD)
M001H BODY COMPUTER (DASHBOARD)
M060A AIR BAG CONTROL UNIT (DASHBOARD)
D227A CABIN/DASHBOARD JUNCTION (CABIN WIRING)
H091 DRIVER'S SIDE CONTROL GROUP (DASHBOARD)
Hi Nikos, did you retrofit succesfull instrument cluster? I want to upgrade my ducato 2017 with 3.5 or 7" instr. cluster. Need also the new multifunctional steering wheel and navi? or can be used those 2017?
On full led headlight, for the moment not working parking lights. To solve easier I need to find headlights wiring diagram for 2021-2024. For the cluster is a little bit different, CAN signal is different, is not just proxi alignment. It is frustrating that doesn't exist cluster model aftermarket with more options. Take a look to this beautiful display, is developed by a team from Russia, I have one identically on a golf Mk4 2000
My friend had issues with headlight
But auto electrician ended up wiring each at a time the doing proxy
And yes that cluster looks brilliant
Can you not speak with the Russians who do this ?
ANY workarounds with the 2022 instrument cluster to work on older pre-2022 ducatos?
Maybe, could anybody with the appropriate knowledge make an adapter device to onvert the signal of the pre 2022 ducatos to work with the latest LCD digital instrument cluster?
would this be possible????
