Mclouis Steel
- Joined
- Jan 31, 2020
- Messages
- 7
- Points
- 3
Afternoon folks; So during COVID alarm fitted to van, it appears in feeding the bonnet sensor wiring through the bulkhead gland a wire from the brake fluid level sensor wire has been snagged. Brake fluid low dash warning on start up . Red light stays on. ECU scan indicates open circuit or short (more likely open circuit. If I disconnect the sensor ... same diagnostic. Not too fussed before now but the MOT is looming. I need to intercept the brake fluid sensor wiring inside the vehicle between the bulk head and the I'm guessing the body computer. Thus any help with the physical location/routing of the wiring would be fantastic. Thanks very much.
