Technical 2019 Ducato EML on P2146 fault code
I should have said injector leak off test as per post 14
Injector variance check good idea anyway
We also got a new ECU and it fixed it for us too.
I hadn't realised, but they took the image from the old ECU, got the image updated and then flashed the new ECU.
In hindsight I would have tried updating the old ECU first as I still suspect an input had drifted out of tolerance and a software update *may* have fixed it. Nothing to lose and might have saved the ~£1000 cost of new hardware.
At least we have a drive able van now.
@jackwhoo throughout this thread is a refference to a leakoff test. Is there a standard Fiat set of conditions for this test, and acceptable test results.
When i did mine a few years ago there were a variety of methods and conditions used on a number of forums but no specific Fiat or VW use xxxx rpm for 30s then xxmins @xxxx rpm ie no standard conditions. Any ideas anyone.
