We have a 2015 Panda Twinair Dualogic which has done 30300 miles. It has been serviced and looked after well and it has been a great little car with no problems. However- recently it started being a bit odd- running really rough on idle and not pulling away as crisply as usual, plus a little bit of creep forward now and then when stopped.
Now we’ve had a couple of times ‘gear not available’. It resets when restarted but obviously not good!
We gave it a full service, new plugs etc, with all the consumables and topped up the gearbox oil. Initially made a bit of a difference but now is as was again.
There’s a small blow in the exhaust which we will fix.
A friend has the computer and plugged it in which gives the error as
‘P060A-79 – Gear control value – Mechanical linkage failure’
Wondered if anyone had had a similar issue here and how it was rectified, and also if anyone can recommend a specialist for the dualogic gearbox. We are in East London/Essex but can travel.
Lots of thanks for any help in advance!
Rob
Rob
