General  2014 2015 Ducato X290 Headlights
davehuge
There's a set of Fiat Ducato headlights for sale on eBay. They're RHD UK version, to fit the new 2014 2015 Facelift X290 model.
Might be useful for someone importing a LHD Ducato?
Just search eBay for 2014 2015 Ducato Headlights or find item number: 251863487483
Hi Dave,
Might you be getting anymore of these in the near future?
Thanks,
Mark
Hi Mark, no sorry, I only bought the one pair so that I could register my new motorhome in the UK.
Regards, Dave.
Regards, Dave.
Hi Dave,
May I ask where you got yours from, or if you know the part number(s)? I'm doing the same thing in importing a motorhome just to register it here, and then put the LHD ones back on!
Cheers,
Mark
P.S. If your motorhome has LED running lights, did you have to get the same for the RHD model headlamps?
Hi Mark
Part numbers are as follows:
1374294080
1374298080
Sorry I don't know which is the left and which is the right headlamp!
Purchased from Tates in Portslade, East Sussex - tatescars.co.uk
Price £397.80 including VAT
These were the version without the LED Daytime Running Lights, instead they have the side light (conventional bulb) lit permanently. That's what my motorhome had fitted originally.
I'm pretty sure the wiring connector will be the same for both types (LED and bulb). I can't see Fiat making a different wiring loom for each type.
Have you made arrangements to change your KM/H speedo to MPH and KM/H? I bought a replacement fascia and it was easy to fit.
Also check your rear fog light is on the correct side, I was lucky because my motorhome came with a fog lights on both sides.
By the way, you don't need a full MOT check to check everything. I paid my local garage £15 to check the lights, speedo and fog lights and type up a letter.
If you need any more information, Private Message me your email address and I'll try and help you.
Good luck! Dave.
Hi All,
Does anybody know the part numbers for the X290 headlights that have LED Daytime running lights? (I note the non LED parts are 1374294080
1374298080 from an earlier post from Dave)
I am also looking for a replacement set for my new motorhome.
Does anybody know for sure if the LED and non LED units, that Dave referred to , are plug compatible?
I have found a price of £265 for the non LED units here 'https://www.amb-trade.de/part/1374294080/6-Fiat,-Chrysler'. Has anyone seen better?
Hi - have just joined the forum.
I'm looking to import a new LHD Fiat Ducato van conversion very shortly (2016 model).
The headlight & speedo replacement seem straightforward but does anyone know whether the current Ducato van comes with 2 rear fog lights or just one on the left? I've searched on the web but not found a definitive answer. It seems a bit of headache to replace and rewire if I need to add a fog light on the right hand side.
Any help would be gratefully received.
Assuming the 2016 is the same as 2015 then the rear fog lights are fine for UK, I can't remember but I think they're twin - passed inspection so must be ok.
