In this day of age, what is the logic of having 2 - yes TWO cigarette lighter sockets? How about both sockets having power only when the key ignition is switched on? (in MAR position). A bit of online searching and have had no luck doing a simple modification of our 2013 Ducato cigarette / power sockets to go 'permanent live'. Yes earlier model Ducato vans have detailed cigarette socket mods but that information was of no use. I also read the different ways of making either socket (or both) permanently wired for 12 VDC, such as disconnecting the 12 volt lead on the back of the socket (which requires dismantling the dash), then tapping a constant 12 volt power source elsewhere via splicing into lines etc. IMO not very elegant. Likewise is putting in aftermarket sockets with separate wiring.. again not very elegant.
With a bit of knowledge in electronics, the method I chose was to do the modifications at the fuse box. I mean after all, there are 2 existing cigarette sockets and having read about some CANBUS system - that's more of a fault protection issue by the ECU.
However doing this modification i've discovered the fuses were not correct. Detailed in photos below:
https://postimg.org/image/lylqg4y73
https://postimg.org/image/ek101i1pb
Taken from the user manual, Cigar Socket is fuse F15 10AMP and Power Socket (other cigarette socket) is fuse F14 15AMP
But when looking at the actual fuse box, F15 had a 15AMP fuse and F14 had a 10AMP fuse (swapped around). Testing with a volt meter confirmed the 180W power socket is fuse F15. Photo below shows my mod where fuse F15 removed and F14 changed to appropriate 10AMP fuse for the cigar socket. The modification was quite simple, ring terminal lead 1 end and other end of the lead was a flat end. White tape label is fuse holder.
https://postimg.org/image/71d9f4kyn
And voila!
https://postimg.org/image/f5ldjv7dr
I did not bother to changing the other socket to permanent live but it's an easy task to do if need. The tricky part is to know when end of the fuse that goes direct to the socket (as the other connector of the fuse would come from the relay once ignition is switched on).
And voila!
