The gearbox are bullet proof! The main fault I see on higher mileage transmission is thrust bearing leak and fail the dot 4 fluid is alway dirty black after time i don’t know what diag system could bleed clutch system we might get some more info off other members
Hi that’s interesting to know ,can it communicate with Magneti Marelli gearbox ecu that’s where you need to be for gearbox work
Youll need the adapter cablesIf I purchase a ELM 327 interface and download the MES 3.9R1 program, will that work on all ecu's including the engine
Hi I can’t comment on that diag software never used it but I do gearbox work on comfortmatic all time they can be troublesome to set up when you’ve bled and removed parts off system e.g setting clutch biting point ,and calibration of gearbox , can mes do all these functions I don’t know also remind you bleed nipple can seize and if anything goes wrong with your setting up ,vehicle won’t drive ,gearbox shuts down and won’t go into gear ,recovery truck to dealer will be the only option £££
