Cinquecento90
- Joined
- Oct 11, 2021
- Messages
- 9
- Points
- 1
Good evening all,
After a fair bit of searching on here, I thought I'd create a new thread in the hope that someone could point me in the right direction.
My 2009 1.2 Lounge has recently developed an issue where the Engine Management Light appears part way through a journey (usually at motorway speed). The issue momentarily disappeared the other day after filling up with a full tank, but has since reappeared. The issue will also reappear after clearing the fault code but this could be a few minutes or few days later.
When the EML comes on it is accompanied by a 'Check Engine' message and the car seems to go into limp mode (very poor acceleration, can't get above 4000rpm).
I have done a MultiECUScan and received the following:
Engine / ECM
Magneti Marelli IAW 5SF8 CF5/EOBD Injection (8V)
ISO Code: 0D 07 67 07 57
Hardware number: IAW5SFHW401 - Ver: 00
Software number: 1308560 - Ver: 0000
Errors found:
P2299-62 - Accelerator/brake coherency - Signal compare failure
P1220-62 - Accelerator pedal potentiometer (feasibility) - Signal compare failure
Body / BCM (Body Computer Module)
Body Computer Delphi (312)
ISO Code: 40 83 AD 86 CB
Hardware number: FI61BC03CL2 - Ver: 03
Software number: 28210065 - Ver: 090A
Errors found:
B10AA-4A - PROXI configuration control - Incorrect component installed
ABS / ABS/BSM (Brake System Module)
Bosch ABS 8 ESP
ISO Code: EC 07 85 86 D3
Hardware number: 0265800800 - Ver: 00
Software number: BB 64461 - Ver: 0801
Errors found:
C1221-86 - Engine control (NCM) - Signal/message invalid
Electric Steering / EPS (Electric Steering Module)
Delphi Electric Steering
ISO Code: 31 83 8C 07 1C
Hardware number: 26132238004 - Ver: 41
Software number: 2613557102A - Ver: 0241
I have wondered whether this could all point to a battery/earth strap issue but am yet to try replacing either of these.
Would be very grateful if someone could please help!
Engine / ECM
Errors found:
Errors found:
Bosch ABS 8 ESP
Errors found:
