2008 fiat fiorino unknown pipe
SenanCarroll
hi guys, just wondering if anyone could help me ? i own a 2008 fiat fiorino. I've had it with about 6 months now and its been running great. today when i went to top up my window washer fluid i noticed some piping cable tied in the engine bay. it is not plumbed up to anything its just sitting there!anyone no what it could be off or should be connected to ?
the pipe goes on hear as the photo
Isn't that the air intake pipe for the air cleaner? As shotguns picture shows
did it go back o.k.?
Hi SenanCarroll and welcome to the forum. You'll usually find answers to your Fiorino/Qubo problems on here as most of us have "been there, done that"!!
The cable tie in your 3rd photo is holding the broken bracket that has been wrenched off as someone couldn't be bothered to undo the nut to release it. If you look up under the back of the headlight, you'll probably see the other part of the broken bracket still in place ;) . You can just see it at the top of shotgun's photo.
Same happened to mine after the 2nd service but I removed the broken bits, superglued the bracket back together and re-fitted.
I can't see it affecting the air intake if you leave the pipe off TBH (y)
Cheers!
