Marmitethecat
My fiat ducato, ive tried to ignore the failing waterpump for months, but now ive ordered one as it making a right noise, but also the alternator is failing too.... voltage reading from 12.7-13.8volts. Im going to put a new belt on too.
I think the tensioner is a 15mm bolt on it?...
alternator i may have bought the wrong one, i was hoping to upgrade it from factory and so i bought a 180amp one, but i have been told this is a bad idea as it will boil the battery and possibly cause other damage as the van isnt designed to run a high amp alternator.. i was thinking to use it for charging a secondry battery ( its a panel van).
Also i have noticed that sometimes when the window goes up the motor carries on running for a bit- if its a sensor fault where would i find this sensor and is it replaceable?
