rrijken1973
- Joined
- May 23, 2017
- Messages
- 6
- Points
- 1
Need expert help!
Used my 2006 Grande Punto 2 days ago last, when I wanted to use it in the evening, I used the gear lever (dualogic car) to put the car in N in order to start the car, could hear the transmission try to get it out of gear and fail but still decided to start the car as it was a cold day and then usually the transmission has difficulty getting into several gears but it solves itself when warmed up. Car stalled though almost immediately. Trying to start the car again will result in nothing happening. Decided to disconnect the battery and let it be to have everything reset and try again the next day.
Next day I get into car, put key in, wait till pump stops priming and press the brake pedal, I can hear 2 clunks from the transmission trying to get it in or our of gear and failing and try to start with key, again a lot of nothing, not turning over at all.
Connecting multiecuscan and scanning the car and it finds body computer and several others, but not the engine ECU or transmission ECU so cannot see what the problem is.
Anybody any ideas? Was going to sell the car next week, but if unable to fix then the car will go to car heaven.
Ah, also just checked the fuses in engine compartment, can't see any blown ones....
Help is very much appreciated!
