Technical 2006 GP 1.4 16v starting fault
stephen m
Hi new to this,but I was wondering if anyone can help ?
had car checked at garage ,they said it was the engine ECU that was at fault ,removed ECU and sent it for testing came back and tester said it was OK(cost £240),refitted still will not start, had body ECU checked thats where the immobiliser is,came back OK (cost £40),had key checked (£50),I've checked all the wiring and I mean ALL the wiring for continuity
ign switch/body ecu/eng fuse-relay box/eng ecu and there's alot of wire's.But when I checked the voltage of the wire from the eng ecu to the starter relay I only got 0.4 volt when I was turning the key to start,I think this is too low and I thought it should have been nearer 12volt ,So can anyone tell me what voltage I should be getting, It's pin 62 on plug 2 engine ecu.​
Hope someone can help,or do I go with the garage and get a new engine ecu, they wanted £350 + fitting
An old and flat battery might be the reason.
My immo was faulty, I changed my old battery and bought a new one.
It's OK now
Hi normal ign lights plus immobiliser light staying on,engine does'nt turn over .I can get it to turn if I give wire 62 a 12v feed thats why I think the garage my be right about the eng ecu
https://www.fiatforum.com/grande-punto-faqs/318839-electrical-gremlin-thread.html
check that little earth to the ecu plug check it into the plug and its connection to engine (clean it)
try slapping a jump lead from the battery (-) to engine block to rule out the earth strap to gear box / engine
Hi just to update,got a new engine ecu and everything is now O.K:)
got in touch with the company that checked my ECU and they refunded
all my money.:D
I looked around the websites and got a new ECU cheaper than the repair. So look before you leap
