Technical  Fiat Grande pundo 2006
Evangelos merk
Greece
Καλησπέρα, έχω μια ερώτηση σχετικά με την ανάφλεξη του ρεύματος. Δεν μου δίνει ρεύμα στο μπουζί. Ξεκίνησε σιγά σιγά να μην παίρνει μπροστά η μηχανή μέχρι που η μηχανή δεν παίρνει μπροστά καθόλου και κάνει πολύ θόρυβο. Το αυτοκίνητό μου δεν δείχνει καμία ζημιά, τι μπορεί να είναι;
Next time use Google Translator for us.
Good evening, I have a question about the ignition current. It is not giving me current to the spark plug. It started slowly not starting the engine until the engine does not start at all and makes a lot of noise. My car does not show any damage, what could it be?
Honestly. Seems like you have no knowledge, no skills to "diagnose" this (I mean, it will take too long). Bring the car to the mechanic.
Or start with basics, like sparkplugs, wires, coil module: https://www.fiatforum.com/guides/sparkplugs-leads-coils-check-replacement-1-4-8v.690/
And crankshaft sensor (car - ECU - does not know it is turning without this, so = no spark, no fuel injection). Check the injectors (is it no_spark only).
While you're cranking, the rev. meter should move (200-300 RPM or so), then the sensor is good enough to start. So it must be something else (other sensors, relays, bad connections including main earth/ground, bad timing, ECU fault - coil drivers fried)...
Check the fault codes (but remember, erasing errors is not "repair"). Must be Fiat group program (FES, MES, AlfaOBD).
